Will be doing the same this year and this sounds like a helpful suggestion and will hopefully mean fewer problems post hibernationEwazix said:Just one other tip, a lot of people have started to mention that their fuel pump becomes noisy (whirring/hum from boot area) after a lengthy lay-up and I had this last year, it disappeared after a few drives but for some it doesn't. It seems to be a well known issue being aggravated by the ethanol content in modern fuels, causing a horrible noise but rarely a failure. My Indi suggested running a bottle of petrol treatment with a protective content in the a tank before laying-up. Something like Wynn's Formula Gold Petrol Treatment seems to fit the bill so I will be giving it a go this winter.
Old-Duckman said:Are the fuel tanks in these cars plastic or steel?
If steel I have heard to store the car with a full tank of gas. Less room for moist air to be in the tank which could allow rust to form. Don’t know...just what I heard on car radio shows.
Ladderman said:If you want a really good battery charger/conditioner, this is the one to get. https://www.ctek.com/uk/products/car/mxs-5-0-uk.
I use it on my z4 for winter storage. Once you connect it, it monitors your battery & only adds charge when needed. The company get really good reviews.
enuff_zed said:Ewazix said:Just one other tip, a lot of people have started to mention that their fuel pump becomes noisy (whirring/hum from boot area) after a lengthy lay-up and I had this last year, it disappeared after a few drives but for some it doesn't. It seems to be a well known issue being aggravated by the ethanol content in modern fuels, causing a horrible noise but rarely a failure. My Indi suggested running a bottle of petrol treatment with a protective content in the a tank before laying-up. Something like Wynn's Formula Gold Petrol Treatment seems to fit the bill so I will be giving it a go this winter.
Not sure if it still applies to modern fuels but can't see why it wouldn't: another issue with leaving a car parked up is condensation forming in the fuel tank. This then runs down into the fuel and forms a layer at the bottom of the tank. As the fuel pump picks up from the bottom of the tank, come the spring it's first big gulp will be water.
For this reason, a lot of people recommend keeping the tank filled to the brim if laying it up for a while. Less air space for condensation to form.
But, modern fuels seem to break down quite quickly and you could end up with a tank full of crap fuel. If you'd left the level lower you could have poured some fresh stuff in to get it all going.
So, pros and cons really.
I just wondered if some of the pump issues may have been due to the water around it? Corrosion? Lack of lubrication? All just conjecture on my part to be honest, but worth consideration.
Ewazix said:enuff_zed said:Ewazix said:Just one other tip, a lot of people have started to mention that their fuel pump becomes noisy (whirring/hum from boot area) after a lengthy lay-up and I had this last year, it disappeared after a few drives but for some it doesn't. It seems to be a well known issue being aggravated by the ethanol content in modern fuels, causing a horrible noise but rarely a failure. My Indi suggested running a bottle of petrol treatment with a protective content in the a tank before laying-up. Something like Wynn's Formula Gold Petrol Treatment seems to fit the bill so I will be giving it a go this winter.
We now have 5% Ethanol mix in UK petrol and it's due to increase to 10% soon, technical bulletins are flying around all warning that a lot of mid 90's and older cars are going to be damaged. Basically Ethanol is hydroscopic so absorbs and holds water, as opposed to it separating in the tank as it used to. Not only is it then causing corrosion in pumps injectors etc but it's acidic and attacks many seals, pipes and filters in older cars causing blockages with microscopic debris. From what I've been advised re the noisy fuel pumps on our cars after a few weeks storage, it's the ethanol/water content causing internal corrosion in the pump when stood. Filling or not filling the tank isn't going to make a difference by the looks of it.
So the answer seems to be to either use the car regularly or use an additive although it's tricky to know which is best with so much snake oil around :lol:
Note: Don't use any of the phosphorus based products designed for classics, they do a great job of protecting against valve recession and other nasties but will kill catalyst.
