WinKFP Question
Greg W
New member
Hello everyone,
I've got a 2003 Z4 E85 that had a faulty left airbag satellite module and I'm in the process of reprogramming it with Winkfp to be able to change the Vin in the donor module. The issue I'm having is when I loaded the Daten files I can go under the data folder and open up the .HIS file and it shows all the module part numbers which match both the original and the replacement module part numbers.
The problem is that in the same data folder I only see two files with the .OPA extensions and neither one matches my current part number so when I go into Winkfp I can't choose the correct ZUSB number. Instead of being 10 different options that were in the .HIS folder there are only the two that shows as .OPA files.
Are the Daten files incomplete, and if so does anyone have the complete file. Old part number was 6931287 and new donor part number is 6933983. The Vin for the vehicle is:4USBT53403LT21027.
Any help is greatly appreciated and Merry Christmas.
Greg W said:
Hello everyone,
Top
Online
Chippie
Contact: Contact Chippie
Post by Chippie » Sat Dec 21, 2024 11:23 pm
https://www.dropbox.com/scl/fi/s7bh0gltdl9do1c6ihx4k/E85.rar?rlkey=yr9b7vpu47k48ukq0aa7ofmtw&st=919ugfow&dl=0
here's a link to an e85 datum, i haven't tried it as i have an e89 but hope it helps
Hi, better solution for finding right module is, run INPA and there are right number from each modules, then you can chose this correct one in WINKFP.
Last Daten files, you can download from inet or buy i think this cost 5$.
But you first have to import all files.
I update new VIN and last FW for E63 BT TCE 1.5 via DCAN (i did it retrofit BT module) , but be carefull via DCAN something do it is not good and take long time. BT module i updated 1hour you can brick you module.
But i think you can load only empty .man files an update module via NCSexpert. WINFKP is for update VIN or update new SW for ECU!
You can see number from each module, this right number you can use in WINFKP, otherweise you can really brick you ecu!
better if its possible this do it via ICOM next (MOST BUS) but in E85 i dont know how many ECU ist connected via MOST.
I ended up reloading Mike’s BMW coding tool and this time WinKFP was able download the daten files correctly and it programmed the module. Coded after that and reset system time to synch the airbag system and all faults cleared.
Thank you for the help.
