EricFlanagan
New member
I have a 2004 3.0i E85 about a month ago I sent my GM5 for repair due to passenger door not unlocking. When I got the GM5 back I connected it and there was a failure probably job not done correctly, the GM5 started heating up and the car went into a lockdown mode. Only when I found the exact GM5 module and replaced it with a functioning one the car unlocked and everything started working again - except for the windows. At first it was intermittent, drivers window would not open, passengers would, then they'd open slowly, then the driver's stopped working and eventually both stopped working at all.
When I press the window button I can hear clicks coming from the GM5 (I guess), also when opening the roof the windows used to slide down half way, that doesn't happen anymore.
I also tried to connect my friend's GM5 (E85 as well) to see whether maybe I purchased a bad unit, that also did not help with the windows.
Any ideas how to approach this? Thanks in advance.
