Windows not going down.
davidpfitz
 London, UK
Hi folks -
The windows packed up today - neither will go down, from either set of buttons. Also, they don't drop the 1cm or so when you open the door. I'm hoping it's just a simple fuse blown - but was wondering where the fuse box is?!
Thanks!
D.
Fuse box is behind the glovebox, there are two clips from memory that release the glovebox from the open position and allows access to the fusebox.
Hopefully yor right and it's a fuse.
Cool ... thanks. Bit tricky to find the tabs to open it up (they're on the top!), but didn't take too long!
I've now got the windows working ... at the expense of the headlight washers! Will pop to the garage tomorrow for new fuses.
Thanks for the help.
D.
