I've just had the passenger window regulator replaced but the garage hasn't been able to get the fitment 100%.
Over about 50mph you start to get wind noise as the glass isn't snug enough against the seal. I purchased the regulator from AutoDoc so it isn't the genuine BMW part, but it wasn't a cheap option. The mechanic said it is not a bad part, but it is at its limit for the adjustment.
So I'm just wondering if anybody has had a similar issue, and if there is a way to get the extra couple of mm needed to sit the glass a little more firmly against the seal in the top corner right?
Thank you.
Thank you.
