Window drop when opening door
kinger
Hi
Today my car has started to drop the windows about 3/4 of the way down when i unlock it and open the door,
Can anyone explain why it has started to do it and is it something that can be avoided? or altered.
Its great when entering the car in a tight spot but not so helpful when its raining hard
If it has just started then it could be the battery replacement gremlins coming out to play. My windows started being odd, new battery cured it.
Are you pressing unlock button twice?
This triggers this on E85/6's so might do the same on E89's
Sounds like the "comfort entry" is enabled. It lowers the window a set amount when the door is opened, to make it easier to get in/out in tight spaces as you don't need to open the door as much.
Mike
Weirdly about a month ago the driver's side window opened all the way when I opened the door!
It hasn't happened since though so I am a bit mystified. :idunno:
As Mike as said above,comfort entry mine did this few times and I thought something was broke until reading up on .
Go to car press unlock twice and only when you open the door will the window drop. :thumbsup:
