Window closing etc post motor replacement
stevedruidstone
 Cardiff
Had the window motor replaced and the window does not seem to be fully closed and there is wind noise above 40mph also has the third up and then down on one push close. Have tried the reset to no avail. The indie has had another look and strip down but can't see anything wrong and suspect free play in a worn button on the switch. Before I replace that any suggestions?
thanks
the switch can't be the problem, esp if all was fine before you had it replaced. I would say that the window needs some adjustment.
