Wind Noise from Driver Window
SamUK
Getting allot of wind noise in the car on the motorway - i can hear it from the driver side window about 2 inches up from the car...
is there any way i can sort this? as it seems to be a window alignment issue?
anyone know?
thanks
Sam
I have the wind noise on my passenger side, tried everything to seal the fukcer but nothing has worked, in the end I just accept it. You can try one thing however, which pulls the window in tighter to the seal. At the bottom of the door there is a grommet, take that off to reveal a nut, untighten that, with your socket still on the nut force it (I say force but a controlled pull is a more appropriate description) pull it out towards the skin of the door, this helps bring in the glass at the top making a slightly tighter fit on the seal. Good luck and don't break anything!
