Wind deflector boot bracket fittings
stevespg
I'm searching for the fittings to put the bracket into the boot to stow the wind deflector- the brackets arrived but I assumed that fittings would also be supplied...
Checking realoem I can't find a drawing which identifies the fitting. Just the bracket.
Any ideas which work? Much appreciated
Are the boot fittings the same as the roll hoop fittings? They certainly seem to have the same slider/clip arrangement. Anyway if the are, I have a spare pair of the roll hoop fittings if it's of any use.
They're different, but thank you
