Will this gearbox oil be OK to use?
toolmanchris
 Doncaster
I've got a couple of bottles of this gearbox oil:
http://lucasoil.com/products/gear-oil/synthetic-gear-oil/lucas-sae-75w-90-synthetic-gear-oil
left over from another car and thought it might be OK for the gearbox in my 2005 2.2 5 speed.
I know it says sealed for life but the change sems to be getting a bit notchy especially first to second.
Now not being that "Into" oil I am not sure if its the correct viscosity etc and hope someone with more knowledge than me could advise.
Chris
Stick your reg in here and get the correct grade:
http://oilselector.castrol.com/c/uk/eng/search
From memory it needs to be GL-4 spec., but check as above.
I would never use oil I had lying around. Chances are it's not the correct grade, it ages, even in sealed bottles and you're taking all the risk of box damage for £20 of oil.
