Looks OK from that angle to my untutored eye.Beedub said:![]()
Here is the 265, 40 section
(No worries on the change of topic for a couple of posts.) :wink:
DLH said:Having taken away some of the shadow around the wheel, it looks like there was a fair bit of clearance from the wheel arch? :?
Just as I thought.....Easty-5 said:Just to add - I used to run 265/40 rear MPSS on stock 224s. They were dubbed "balloon sidewalls". They didn't look great and on track, under heavy cornering they would rub the inner wheel liner. That's with stock 224s, stock suspension, Eibach springs and a CSL geo.
You can see there how soft standard suspenion actually is under duress.
DLH said:I may actually be able to go with Michelin PSS's after all as I emailed Apex Raceparts about tyre fitment and got this reply:
I believe that those sizes are available in PSS's, so perhaps that's the way to go, although it's all a bit confusing to be honest.
- Thank you for your interest in our wheels.
In stock form, the 18x8.5" ET38 ARC-8 front with a 18x9.5" ARC-8 rear would be the proper fitment for a Z4M Coupe, and would have a flatter front and a concave rear. The proper tire sizes would be 245/40/18 and 275/35/18 for these wheels.
Now I can't decide whether to go with the wheel manufacturer's tyre size recommendations in MPSS (I keep thinking that they should know, right?) or to get the 235/40/18 and 265/35/18 tyres either as Eagle F1 AS2's or as Vred Vorti's. :?
Imagine if your alignment wasn't track biased. This would rub like a mofo.tertius said:DLH said:I may actually be able to go with Michelin PSS's after all as I emailed Apex Raceparts about tyre fitment and got this reply:
I have a set of Apex wheels, EC-7 (sizes - 18x8.5 ET35 on the front and 18x10 ET25 rear); tyres are MPSS 245/40 and 265/40.
I do get a small amount of rubbing on the front, but only on track - e.g. heavy braking, into dips that sort of thing; none at all on the road, however, my suspension is far from stock - Intrax 1K2 with quite a bit of negative camber.
Beedub said:Imagine if your alignment wasn't track biased. This would rub like a mofo.
