Which one do you use??
jakblade
 Lincolnshire
Iron contamination remover. Which one??
Carpro IronX, Autofinesse Iron out, Valetpro Dragons breath, Gtechniq W6, Dodo Juice ferrous dueller???? Or another??
BH Korrosol is awesome stuff but I'm using Carchem Revolt, stinks, but they had it on a group buy last year so I bought 5ltrs.
It works as well as the BH.
Carpro ironx, we go through 1/2 gallon a month
Been meaning to make the switch over to iron X ls (contains more active ingredients)
But you get so used to using the same one over and over that you don't get the stink from it, don't want to go through that all over again
We've tested loads of iron/fallout removers and always go back to iron x, always find with other branded ones that although you see the panel/wheels turning purple from reaction, thinking that it's "cleaned" even after a second application, but 9/10 following it up with iron X showed that there was further contamination where product c did not have the abilities to clean the same area
Everyone tends to go for what's cheapest these days anyways :tumbleweed:
TBH the reason I asked was I have been using Iron X and have just run out. Thought I would gauge what others were using to see what options were out there and that were any good.
Decided to give the Iron X LS a try.......only time will tell.. :D
We're actually looking to begin to stock Iron x-ls in the near future too, seems to go down well with a few people, much better than the cherry scent :rofl:
I can however recommend not to sniff this one either though!!
