Hi, I've found Ctek to be a good choice having wintered two cars on my 3.6 model for two years, the Zed is still on it's original 2003 battery and is excellent!
If you are spending I would seriously go for at least the 3.6 model which has additional functions like de-supherisation, pulse charging and has a useful frost mode if you are outside. My 3.6 came with the fixed battery leads which are permanently fitted in the boot and you don't have to disconnect the battery, just pop the eyelets over the battery post clamp bolts and leave the lead/plug in-situ. I've found the cable will happily run through the boot rubber seals without damage or leaking so the unit can sit in there if you wish.
Where did you purchase this kit from? Was it direct?
Without getting too tech'i there is a lot of misunderstanding about lead-acid car batteries and how they charge. Basically a battery that appears to have been 'fully charged' on fast or even a steady trickle charge is probably not fully charged at all. Most electrical charge sits in the electrolyte at the plate surfaces, it will take time for it to dissipate throughout the electrolyte, which is why you can 'fully charge' a battery, leave it a few hours and find it will accept substantially more. (which explains some peoples concern that the Ctek charges then keeps staying on for long periods - if you get this reconnect and re-set the unit you should find that it will settle to the green monitoring function after a while, but would probably do it anyway if you are patient - unless your battery is knackered or you have a current drain)
Battery conditioners like Ctek 3.6+ monitor and adapt optimum charge rates, and only when more charge can be accepted do they add more.
LA car batteries are ideally stored disconnected when not in use, leaving them connected for 2-3 weeks or more will start the process of sulpherisation of the plates which reduces their efficiency, battery conditioners periodically reverse this process and keep things tip-top.
I wish I'de bought one years ago it saves money on knackered batteries and grief when you come to use the car - Ctek 3.6 or higher is recommended
