Which cheap wheels for track day set?
ga41
Paphos
I'm thinking of getting another set of wheels for track days, not right now but eventually i will. Any suggestions on which ones to get? Ideally they'd be light and i'd probably prefer the same ones all around so i can rotate them. Maybe 9" wide everywhere? Don't know a thing about offsets and stuff though. Oh and i've already got Stoptech's 355mm brake kit on!
I was thinking about Team Dynamics Pro Race 1.2 as they're pretty cheap and have a good reputation. http://www.teamdynamicsracing.com/pro-race/Pro-race12.htm Other suggestions?
Would a set of rear OEM wheels, which are 18x9 with 30 offset, fit in the front of ours? It says here: http://www.willtheyfit.com/index.php?width=225&aspect=45&diameter=18&wheelwidth=8&offset=42&width2=255&aspect2=40&diameter2=18&wheelwidth2=9&offset2=30#content "Compared to your existing wheel, this new wheel will have an inner rim which is 0.7mm closer to the suspension strut. The outer rim will poke out 24.7mm more than before."
My suggestion for choosing the wheels for track days is also Team Dynamics but I like Pro Race 2 as these are in black color and looking prettier as well as low in price. I think you should chose Pro Race 2 black wheels for adding more beauty in to track days. Check out its picture here.
Actually prefer the multispoke look of the 1.2's but to be honest i don't care much how they'd look. I just want them cheap, light and most importantly to fit properly. At the end of the day i'm only going to have them on 4-5 times a year so looks is not a priority
Anyone? Where are all the track junkies? Does 18x9 with offset 30 fit OK in the front of our cars? I will be running more negative camber than stock at some point
