Wheels
That is a bit of a vague question J?? E89 85-86 M non M????
What are the spider wheels offsets widths. No one is gonna be able to help much with out that information mate. Stick a picture or number of the wheel up at least :thumbsup:
Hmmm, I've seen the car with them on I was just wondering if they're properly compatible or likely to cause problems over time,
Don't know how to post a picture here,yet ?
I'm running a ET27 9j 19" rear and don't have any rubbing, however I am running coil-overs and a 1.5 neg camber.
99.9% Buying this pending MOT tomorrow, hope the link works
What do you all think ?, please feel free to be as brutal as you like :D
http://www2.autotrader.co.uk/classified/advert/201609027377711?logcode=kp
Not too bad for that kind of mileage I think. Doesn't really have a lot of options and still has the orange indicators though. All depends on your time and budget. :-)
Well to say they don't fit is wrong they can fit but involves work. Or you can buy replica wheels with different offsets.
I had M3 CSL wheels 9,5 rear (ET27) and 8,5 front (ET38) with 255 rubbers rear and 225 front. With no extreme lowering I had no issues, even had spacers in the front. And non-M of course.
It says they are genuine and they look it. The fronts will be fine the rears could be a problem but a 255 tyre and some negative camber should all be good.
I have these on mine and had major rubbing with the crap FK springs. And then minor rubbing with coilovers. I ended having to machine 2 MM off the wheel. Go for a test drive try and find some usual ting road if it rubs exceseivley don't buy it!
I actually quite like the look of that with M3 wheels on it. Looks a bit high at the back for a 3.0 that should be on M Sport suspension. Makes you wonder if its the angle the cars at, or the effect of the different wheels, or have the rear springs been replaced with the non M Sport ones in error. Don't like the after market stereo but its got heated seats which out of all the options is for most "the one to have" along with the wind deflector. Its also got rear parkers which along with two I've already mentioned would be first on my wish list along with xenons.I like zeds without sat nav, I know for some its compulsory, but I'm not a fan of Sat Nav equiped E85/6 cars as I think it looks like an old CRT TV on the dash. Each to their own and all that. Headlights don't seem to have silver inners which is odd as this was standard on the 3.0i, could just be the photos. Not a fan of powerflow exhausts as they are usually just cobbled together rather than a properly designed and tested system, but maybe yours is well executed and hopefully sounds nice
Technically the rear isn't a coilover. It is height adjustable though. :thumbsup:
