I was having major issues with tramlining on mine and knowing basically everything on the front and rear suspension has been replaced fairly recently (sub 5k) and the alignment was spot on I started hunting around for the culprit. I started by taking the F15mm & R20mm spacers off (as I was thinking scrub radius) and it improved things a little. I then reduced the front camber to SE spec from being maxed out, again a slight improvement. In the end I bit the bullet and replaced my Michelin PS3 front tyres with over 5mm of tread on them and no obvious funny wear with brand new goodyear F1s, that finally sorted it. That was about a 1,000 miles ago and still going ok. I re looked at the old PS3's off the car and under a real close inspection I think the tyres look like they may have worn ever so slightly funny. It extremely minimal though. Very very slight feathering I dont know if this is a result of the previously worn suspension components /front track arms/rear bushes etc, the maxed out camber or the alignment being out pre the suspension work. TO be honest it could be a combination of all of them. Or its that minimal it could just be normal wear for that tyre. With that in mind I'm about to (when I get around to it) try to refit the spacers and see what happens, if that goes ok I may max out the camber again too just to see what happens etc
