Jembo said:
One of these are very useful, both for taking wheel off & back on ALLOY WHEEL ALIGNMENT TOOL - BMW X3 E85 (2003-10) M14x1.5 REMOVAL NUT BOLT -1T3 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F323409095707
Remember to always undo locking nut first, crack bolts before jacking, piece of wood to block Opp sides & look for a low lift jack (alloy ones from Costco are ok), as normal ones are too high
Thanks for the reply.
Interesting regarding alignment tool. Guess that acts as a third hand and makes it easier.
Noted on jack, found one here.
https://www.costco.co.uk/Hardware-D...Low-Profile-Trolley-Jack-Model-03675/p/253398
When you say wood to block opp sides, presume that is if taking off both wheels from one side, so block two opp side.
Can you get both wheels off one side from a single jack point?
