Wheel Nuts
H14ytr
Hi All,
Does anyone know if the Roadster S wheel nuts are the same as standard BMW Z4 E85 ones please? I know they appear to have their own Alpina part number but without taking one out I cant compare them to standard ones? At £20 each its an expensive job to change all 16 on top of the £80 I've already spent on Alpina lock nuts.
Any help would be appreciated and apologies if this has been covered in an earlier thread somewhere...
It's a Z4. I can't think of any reason why they would not fit. Though they may well look different to the trained eye. :)
It's just the fact they've got an Alpina Part # that's making me think differently mate.
I might just have to take one out when I head to Sytner's tomorrow and compare the two if no one has a definitive answer this evening.
Cheers Mate
They may have a different shoulder profile (angle) and possibly length to standard.
I could check mine against the E89 for you but I have Classic wheels, not Dynamics so they may also be different.
I can swap one of mine to check for thread sizing and length if that helps a bit? It may not as neither of my cars is the same as yours (E92 and E89). :|
Once you confirm what bolts you need, you will be able to buy them from eBay for example at around £1.00 each. :thumbsup:
Thanks for this mate, please don’t go to any trouble I’ll drop one out and compare at Sytner tomorrow. I’m always a bit dubious about using none genuine parts especially on wheels etc but guess as long as the profile is a perfect match they all do the same job.
I’ll keep you posted and thanks again for your help.
A bolt is a bolt is a bolt TBH. The correct torqueing is far more important than the bolt itself, as over-tightening stretches the threads and hence weakens them. I would expect the shoulder profile to be pretty standard. I think the reason for the Alpina specific part number is that it is an 'accessory' to the Alp specific wheels.
£20 each is daylight robbery.
