The front should fit, but the rear looks a little too big for the 2.5i. There are quite a few more knowledgeable people around here that should be able to give you a definite answer.
Edit: just took a second glance at the offset for the front,,,gonna be real hard to make that fit properly.
I have no idea what offset you need in an attempt to get a wheel in that is 3" wider and 2" greater in diameter than the standard 2.5 spec wheel (Style 104 7J 16" running a 225/50R 16 tyre). Even the 3.0 only goes up to an optional 8.5J rear 18", so a 10" rim on a 2.5???
Of course the wheel size does not decrease the engine power per se, however it raises the effective gearing and reduces acceleration by sapping power trying to spin up all of that increased radial mass.
