Chaps, need a bit of help/advice and thanks in advance.
I've had a wheel off the car to clean and protect for winter. Silly old me has managed to knock a 5 gram balancing weight off. You know how they stick them in a line together, well, the one at the end of the line has come off. Also in the mix is that I've now daubed wheel seal all over the area.
The question, in brief, is can I stick this weight back on and how? I have superglue (2 elements that you mix together - probably the glue and the hardener I guess) or I have... some honey?
Would I be better off taking a trip to a wheel shop and asking for some of the rubber tape/glue stuff (the spongy black rubbery stuff that sits between the weight and the metal of the wheel - mine has disappeared from under this particular weight) and self-applying at home?
Many thanks
Stevo
Many thanks
Stevo
