What's the widest wheels and tires that can fit?
ari1856
I have access to a wheel company that can make any sized forged wheel in any offset you specify down to the millimeter.
On my 911, I was able to get 12" rears with 315/30-18 and a 9.5" wheel with a 265/35-18 up front. If you know porches, these front wheels are a whopping 1.5" wider than stock and 40 mm wider. Additionally, the car really looks like a race-car. There is zero rub under any compression or turning radius which is a big plus. Under-steer has been practically wiped out with a more aggressive camber setting, and H&R rear bar and some negative camber.
As you see I'm not trying for the 20" bling wheels, Just something with the maximum width to maximize dandling without killing the ride an dhadling.
So... what's the widest setup anyone know about. What tire sizes and offset info would be great!!
Depends if you wish to go 18" or 19"???
with the 18" you can shoot for 9" wide front wheel, offset needs to be around the 40 mark, with around -1.9 front camber, its Really close but it Should be cool...
The rear can take a nice 10" wide wheel with a Max of 275 section tyre.
19" you can run 8.5 wide fronts, +30 offset for a proper flush archline then add -2.5 camber and you'll have a great look, your understeer will be greatly improved, But remember you get less warning when the rear becomes mobile.
on the rear 19" you can again run a 10" wide rim but tyre selection is crucial.....
ive got the bbs ch blacks in 19 "
front 8,5j x 19 et 35 /tyres conti sc3 235x 35 x19
rear 9,5j x19 et 40 / tyres conti sc3 265 x 30 x 19
fronts rub the innerscreen when a speedbump or e deeper dent in the road comes up
but otherwise no problem
275 rear tyres will fit but then the match with the front diameter wil be to far apart.
edit: this is with the oem M suspention!
