Andrew*Debbie said:Wait, the reading on that gauge is real? I assumed it was a software simulation.![]()
GSARider said:A further question, how many of you let the engine tick over for a while before setting off and for how long...?
I allow at least three minutes normally.
GSARider said:Have done so for the past twenty years and in fact all older cars used to specify in the handbook to allow a warm up before setting off.
sars said:GSARider said:A further question, how many of you let the engine tick over for a while before setting off and for how long...?
Do you just sit in the car for 3 minutes?
As maniac has stated, at idle, oil pick up is minimal, the result of which will be to cause the rings and liners to wear quicker. This might not be a problem for you, if you only keep the car for three years, just the guy who buys it down the road from you.
and the comment that I have been doing it for 20 years does not necessarily make you right
jaz4 said:I would have thought the engine and management system would stem the throttle if it was going to damage the engine in any way.
