mambot said:I think that may strategy will be to use whatever is cheapest and then to fill it with some high end stuff every so often to flush the tank through.
cj10jeeper said:I'm not sure I hold with this idea that a couple have mentioned of running to 'fumes' or 'bone dry'. It's not uncommon for there to be a layer of water on the bottom of the tank, not to mention the general build up of sludge and silt from fuel and of course in older tanks corrosion.
Any of this will if lucky just clog a filter, but would have dire consequences going through injectors.
Just a thought for the day
Shipkiller said:cj10jeeper said:I'm not sure I hold with this idea that a couple have mentioned of running to 'fumes' or 'bone dry'. It's not uncommon for there to be a layer of water on the bottom of the tank, not to mention the general build up of sludge and silt from fuel and of course in older tanks corrosion.
The fuel filter is in the fuel tank. You cannot get to it to clean it. You must drop the tank...
+1 when it needs it in the summer....enfield said:Shell V-Power because it is the only brand without alcohol in it (here in Canada).
pvr said:Is there a particular reason why the feeder pipe / filter is not at the lowest point in the tank so that you would never have a place for sludge to be?
Also, if you run on say .25 of a tank, wouldn't the petrol get shaken so much in the tank that it completely mixes anything that is in the tank?
Justinitus said:mambot said:I think that may strategy will be to use whatever is cheapest and then to fill it with some high end stuff every so often to flush the tank through.
The only "Premium" fuel I have anywhere near me in Northern Ireland is BP Ultimate and on a friends advice, ran the tank down to fumes and filled up on Ultimate.
Noticed an immediate difference in the mid-range and responsiveness in my 2.0i Sport and it seems to run smoother too..... worth the extra few pennies I think!![]()
