GuidoK said:I don't think the spring wire size is thàt thickexdos said:The problem with the Z4M's OEM suspension, particularly the E86M, is the rear springs are way too stiff at 19mm thick and the front springs are way too soft at 11mm thick. Any of the aftermarket adjustable suspensions which have rear springs of around 16mm thick and front springs of around 14mm thick will be a considerable improvement on OEM , especially when you can also adjust the damper settings to suit your purpose. For a "general purpose" Z4M that set a few trackdays, KWV3 or Bilstein B16, with stainless steel dampers, will be ideal.![]()
See my posting here: http://www.z4-forum.com/forum/viewtopic.php?f=9&t=38918&hilit=suspension&start=30 dated Thu Jun 28, 2012 6:48 pm with the photo to prove it.
