What are the OEM discs / pads?
jmb
I noticed one of my front discs is only shiny across the inner 2/3rd's (and they'd noticed it was scored at the last MOT) so I probably need to sort those out.
Before I call up BMW to laugh at how much they charge, does anyone know what the OEM fitment is? I had a quick look on ECP and they list everything from Eicher (weirdly two, one is £30 the other £33?) thru Pagid at £38, Brembo £40, ATE £43 and Bosch £58...
Likewise Pads I guess, a range from £28 for Eicher up to £65 for ATE
I assume you are talking E89 But you need to state what year and what engine. there are differences based on these factors. I have my E89 S drive 3.0i 2009 at present with the brakes stripped down. The pads are front Jurid 422FF and the rear Textar T 4689FF .I believe these also suit the 2.3 . Can't really help with discs but I would choose Brembo or ATT . There was a post on the forum re pads under the title " OEM Brake pads textar e pads " this may be of some use no doubt it can be found in search.
