Water Pump Leak
When putting coolant in I think you have to either raise her or park uphill with heater on and bleed valve on expansion tank opened
http://www.pelicanparts.com/techarticles/BMW_Z4M/15-WATER-Draining_and_Filling_Cooling_System/15-WATER-Draining_and_Filling_Cooling_System.htm for the 3.0 not sure if the 2.5 is the same
Thanks for all the advice gents,
Ended up doing it in the garage with a mate and changed the water pump, lower radiator hose, thermostat and both alternator and compressor belts.
On a different note the paint of the car is coming off at places due to being parked under the sun all these years. Any advice? (low budget advice haha)
