Water leak
Hi all, my Z4 has been losing a small amount of water for a while now and I've finally tracked it down to a pinhole leak in the expansion tank. I've got myself a new expansion tank ready to be fitted this weekend, but does anyone know the capacity of the cooling system? i.e how much coolant am i going to need to buy.
[ref]MarkG - E85[/ref], you shouldn't lose all that much tbh.
I did one for Jock156 a week or two back and we only had to top up about 2.5 litres.
I put the front of the car up on ramps so I guess it prevented too much running out.
Just checking, you car's not an auto is it?
EDIT: looked through your previous posts and you've mentioned a clutch, so that's answered my question. No need to worry about the self-destructing oil cooler thermostat inside the bottom of the expansion tank then. :D
MarkG - E85 said:
Cheers Enuff, no it's a manual box. I was planning on putting mine up to work on it so hopefully i won't lose that much.
When you disconnect the hoses you'll see one goes to the auxiliary pump on the left inner wing.
When you reconnect that make sure it is clear of the pulley on the front of the engine.
I think there's a clip under the air box if it needs to be held away.
MarkG - E85 said:
Oh eck, i can see me messing this up :D
It's a 4-pot though, so loads of space to see what you're up to!
Take a good look before you start and all will be fine.
