Hi all
I have noticed over the last week or so that when I park at work on a slight slope that water drips from the drivers side rear jacking point. At first I thought it was the roof drains, but when I looked under the car its dripping from the pin that is in the middle of the jacking block. It stopped after about an hour. Today we have had quite a down poor and its started dripping again. Its now been 3 hours since the rain and its still dripping. Has anyone else had this problem? I have checked around the block and its all dry it is only coming from the middle of the jacking block. Not doing it on the other side only the drivers side.
- apparently there is a drain each side from the scuttle and the drivers one gets blocks and fills up the side panel with water [which then goes slosh / slosh when you drive] I have this issue, but if you leave the jacking point a bit loose it will drain away - especially when you drive away
