Water drainage roof door seals
Hi I'm new to the forum so hello to everyone .
I'm after a bit of advice my car 2007 Z4 has just come back from BMW having a little spray work on rear drivers side quarter sill where the roof sits on top as it started to corode slightly .
I believe that the work may have been subcontracted out as the car came back with overspray all over which needed to be cleaned and I don't believe that the seals have been fitted back correctly . They have also managed to crack my 3rd brake light . Noticed that there is water on the inside door sills is this normal as don't believe I had it before .
There is now a drainage type pipe sandwiched and exposed on the drivers door seal that hasn't been put down correctly .
Just wandering what other think .
