Water collecting in rear quater???
Had to discribe this one, when the roof is down just behind the drivers seat in the rear quater panel where the roof bolts in.
If you look down there i have about a pint or so of water that i have to keep sucking out.
Checked and cleared both drains, Any ideas?
I have had this and it was the roof drains, are you sure you cleared them properly or they haven't become blocked again?
We used hot water (to soften the mud/debris) a flexible rod and a garage air line. The air line did make all the difference, I was lucky I had access to this as I did the job at a friend's repair garage.
What a s**t idea idea mite be a little bit lucky then that the motor side is dry for the moment anyway.
Looks like its a roof off job to do it right then :headbang:
I bet 5 years from now these will be rotting in the sills worse than a british layland car did in the 70,s !
Except for the sills being plastic
Nah, my car is 13 years old now, anything BL of that age would have been coke cans and hair clips by now :rofl:
