Let me be the one to put my head up and be shot at, but something is wrong here :thumbsdown:
So the science (lifted from Z4 authors that know a bit about it):
The BMW roof is a multiple layer structure (I refer to the power roof as the manual is thinner and different structure) The outer is 3 layers of polyacrylonitrile fibers, polythene fibers and underneath a butyl rubber layer. Below this polyurethane film and then inside polyethersulfone. In simple terms the outer fibres (the bit you see) reduces noise, the middle is waterproof and inner insulation and soundproof.
Bottom line is that the outer layer is not supposed to be waterproof!!! - it's a permeable layer and you've just defeated one of the key features of how it all works.
Might look good for now but IMHO not a good thing to do to a roof that will cost £1000+ to replace, has to last 10 years + must be flexible and stay good looking.
BMW make a perfect roof protector, as do Ragtopp. These are the top products and the latter is endorsed by pretty much every softtop company and neither of them cause beading of any sort (I know as mine is well treated with it). Tent waterproofers are designed for that - waterproofing a tent, designed to last for a season and usually to stop leaking caused by touching the inside of the canvas (I'm a keen camper and use this stuff on my tents...)
All I can say is stick to the correct stuff and not spray £5 tent protectors on it when the correct stuff is not much more expensive and proven.
Fire away
