Wanted: Set of rear coil springs for a 3.0i (M-SPORTS)
Patrick_g46
 Leamington Spa
As above, looking for either a new set or a set with little miles on them please. Let me know what you have :thumbsup:
Patrick
Er.... good question. I would be guessing if I gave you a number. The paint on the spring is in great condition, so can't be too high
Hi, I have a full set of M springs in a box that I replaced on my Z4MC. They have only done 25K miles and in perfect condition. £50 and they are yours ;)
Random question - is there a difference between the M springs and the Si Springs (assuming SE springs are different anyway)
Cheers for the offer but as said by adam I am after a set for a non-m car but on sports suspension, bit confusing!
I might give it a miss then as if I am replacing both I would ideally want them to be worn the same amount! cheers though.
ShaanK said:
Thanks fellow Edinburger :)
So is there a any benefit in say upgrading from Si to //M springs?
No real benefit. The springs and dampers will be designed to work together with one another, and it could throw the handling out a little. The ///M suspension is firmer at the rear, there's a massive thread on the subject by 'exdos' in the 'M Specific' section of the forum. I've never had the energy to read it all though :lol:
Can anyone tell me if the springs from a 3.0i and a 3.0si are the same?
Eurocarparts appears to stock the same spring/part number for a 2003 3.0 and a 2007 3.0 (which is an "si") so I guess they are...
