Wanted - Rear quarter panel / Wing- Right/drivers E86 Coupe
Newbers
 St Albans (one days march from London)
Following an unfortunate reversing incident on the part of my wife I have two damaged cars... :x
Shopping here for a rear drivers side quarter panel for a Coupe i.e. the one with the filler cap in it.
OEM code is: 41003427224
I've seen one on ebay for £160 but that seems a bit dear for one in a breakers that will probably have dings in it (am I being characteristically too tight?)
I haven't checked dealer price but I was thinking if I could swap it over myself and then get it sprayed that would be a bit cheaper.
I must be meaner than I thought (it happens a lot!)
It would be great if it were the same colour - at least then I could fit it and only worry about spraying the outside not all around the boot etc.
There's a sterling grey (which is what I need) on ebay and loads of roadster wings around, I might just need to be patient about this one....
That's what I did when I wanted a nearside front wing and later a boot. I managed to secure both in Black Sapphire and collected both so I could ensure they were straight and undamaged and check with my paint meter to ensure they were factory paint. Both panels were around the £160 mark each, and I did have to travel 180 miles for both also, but managed to tie in with business so not an issue. No respray required on either so very cheap when you think about it.
That's the perfect scenario - how find them? Online breakers or ebay? Or another cunning means.....
Still looking for those hen's teeth if anyone should hear about a coupe at a breakers...
