WANTED: Mediabridge
Gonzo
I'm looking for a mediabridge if anyone has one they are not using any longer.
Preferably one of the newer audiovox ones, but would consider the dice version.
Thanks!
I guess you wouldn't be interested in the small, cheaper Yatour adapter ( http://www.ycarlink.com/pd_18878_BM4H-for-16-9-navigation-BMW-models-USB-SD-AUX-Car-Digital-CD-changer-interface-adapter.htm ) with DSP adpater ?
Thanks but I'm wanting to use the a2dp music streaming function of the media bridge which I don't think the yatour is able to do?
How much are you looking for? (Sorry for the thread hijack!)
The Yatour is able to do it if you add the BT module (which i don't have).
With DSP adpater, i guess around £60.
If this works in a 2007 Z4MC with prewired bluetooth then I'll have it if the other guy doesn't want it.
Go for it mate.
Scooba_Steve said:
Dension ice link plus and aux adapter any good to you?
Scooba_steve...........Have you got a link or can you (or anyone!!) advise on what the dension does,
Ive got an AUX cable fitted at the minute but would like a better piece of kit(instead of a cable lying on the passenger seat and the phone falling on the floor everytime i floor it round a corner!!!)
If by "work", you mean streaming music with A2DP through the prewired BT, no, it won't work.
To use BT A2DP for music streaming, you will have to buy the BT add-on module for the Yatour. The music will go through the Yatour and the CD Changer connection.
But your prewired BT will continue to work like it does today.
Thanks for the different options, but from looking at what I'm trying to achieve the media bridge seems to be the best fit. A2dp streaming is so easy (plus less visible wires). I've tried a blackberry gateway but get horrible 'power noise' feedback.
I'm also planning to put a qi charger in the car, so effectively no cables on show at all.
http://www.gumtree.com/p/cars-vans-motorbikes/dice-mediabridge-ambr-1500-bmw-e46-x3-x5-z3-z4-m3-m5-mini-5-series-7-series/1074588472
Is this what you're after?
