FWIW Ala5dair - Are you sure they were after market xenons, or was it just someone trying to used "Xenon" bulbs in a halogen unit. I say that because they're are NO aftermarket xenons to the best of my knowledge. I tried to find some for ages because I wanted a set with "angel eyes" / Halos but ended up cutting my headlights open and making them myself.
[/quote]
Hi IamOrion
I’m not suggesting that anyone should run one side halogen and one xenon. I’m new to the zed, and I know little, but I know enough to know that would be crazy.
Ref the aftermarket lights, mine were fitted by www.dynamicperformance.org who are still advertising them from £145 per pair. I believe they use the original housing but replace the halogen bulb with a HID ballast and xenon bulb. I certainly get a very bright, very white light, far better than the original.
According to recent MOT changes, though aftermarket xenons are supposed to be an MOT fail. I discussed this with my mechanic who said that this was nonsense as far as he was concerned. If the car has xenons he is not allowed to investigate whether they are OEM or aftermarket - not even to remove the rear cover.
So, he replaced the headlamp I have with a new OEM (Hella) to match the LHS, replaced the Dynamic xenon kit and passed the MOT.
Coming back to your issue, Crimson_27, it may be safest for you not to take the risk with my halogen, unless you can get another, and then look at a conversion from http://www.dynamicperformance.org/headlights...?
