K kev m Member Wiltshire Jan 16, 2016 #1 Has anyone got a 3rd red break light that would fit a 2004 convertible. Cheers
S Scooba_Steve Lifer NW London & Somerset Jan 16, 2016 #2 If you don't have any luck here try Soper Lincoln and make sure you get the reduced tension springs and washers. Clear are cheaper than red.
K kev m Member Wiltshire Jan 16, 2016 #3 Thanks for the reply. Do you have there contact details ? Cheers
T Toe-side Senior member In the 'Borders' Jan 16, 2016 #5 Buy a new one. Generally second hand ones will suffer the same issues as your old one £50-60 ish clear or red
D Dav the wheel nut Lifer Somerset Jan 16, 2016 #6 Toe-side said: Buy a new one. Generally second hand ones will suffer the same issues as your old one £50-60 ish clear or red Click to expand... Yep these break lights do brake
Doddsy Senior member Newcastle upon Tyne Jan 16, 2016 #7 Scooba_Steve said: If you don't have any luck here try Soper Lincoln and make sure you get the reduced tension springs and washers. Clear are cheaper than red. Click to expand... Hello, I've just ordered a clear third brake light from BMW today. Do you know if the springs and washers are included in the box? Cheers
Z ZedFourM Active member Hampshire Jan 16, 2016 #8 Doddsy said: I've just ordered a clear third brake light from BMW today. Do you know if the springs and washers are included in the box? Click to expand... Nope - you normally need to order them separately. B63.25.9.128.043 x 3 B63.25.7.151.981 x 3
