Lazza said:The voice control on my E89 35i doesn't work. It always says it can't hear me. Gives it 2 goes then gives up.
Should it work? Does it work for other people? I have a dealer warranty on the car so if it is supposed to work I will get them to fix it.
willgill said:It's completely useless anyway, you aren't missing out on much![]()
mcbutler said:willgill said:It's completely useless anyway, you aren't missing out on much![]()
Disagree, mine works brilliantly. You probably have dust build up in/on the mic (wherever that is)..
iDrive with Nav.Maniac said:Idrive (nav) or non iDrive car?
I haven't missed it at all. Not sure what I'd want to use it for. What I can't do from the steering wheel I have programmed into the 8 buttons anyway. If it should work I'd like it to work though.willgill said:It's completely useless anyway, you aren't missing out on much![]()
Wouldn't it be the same mic as used by the bluetooth telephone? I have no idea where it might be but it's clear enough when used for phone calls.mcbutler said:You probably have dust build up in/on the mic (wherever that is)..
Your probably right Will, do you remember when you did the carly work on my car, you were waiting for a remap. What figures did you end up with after that was done??Lazza said:iDrive with Nav.Maniac said:Idrive (nav) or non iDrive car?
mcbutler said:Your probably right Will, do you remember when you did the carly work on my car, you were waiting for a remap. What figures did you end up with after that was done??Lazza said:iDrive with Nav.Maniac said:Idrive (nav) or non iDrive car?
Pretty nippy thenwillgill said:mcbutler said:Your probably right Will, do you remember when you did the carly work on my car, you were waiting for a remap. What figures did you end up with after that was done??Lazza said:iDrive with Nav.
yes of course matey, 428hp in the end![]()
