Viewed a car in need of TLC - Avoid or take the plunge
s.m.456
I went to see an E85 3.0i yesterday and it is in clear need of TLC. The car has a 'full' service history from a local independent garage....
I went to view with the knowledge the roof does not work, so that had been factored into the asking price. However there are further issues which would need addressing. The car has 102k miles on the clock.
- Valve cover gasket needs replacing, visible seepage around the valve cover.
- Oil filter housing gasket. Same as above.
- Wheels, 17" turbine style. Curbing as expected but also some relatively bad corrosion where the lacquer has gone completely.
- Both the auxiliary belts are cracked and need replacing.
- Lips to all discs, not 100% of thickness so may be o.k.
- No evidence of water pump replacement.
- A audible whine at speeds between 20-40 mph. Potentially a wheel bearing.
- Other cosmetic imperfections, in-line with the age and mileage of the car.
Now I've listed the above out, it sounds like I should avoid this with a barge pole. However on the flip side if there are relatively few additional surprises, I could end up the piece of mind that all the preventative maintenance has been carried out and be trouble free for the foreseeable future.
With the roof motor replaced and relocated to the boot, wheels refurbished, and a good DIY session over a few weekends I'm half tempted. :evil:
Am I bonkers?
Depends but price I guess mate.
Wouldn't say it has been looked after though if all those thins need doing. I'm sure you will find out that it needs new front and rear bushes shortly too so may not be the bargain you though.
All that stuff could be easily rectified imo and a lot of those issues were present when i bought mine last summer.
easy fix. did mine.
did mine. easy fix. swap in new belts, stat and water pump at same time.
easy fix by refurbishers.
as above for oil filter housing gasket
ok for now. pad condition/wear?
swap in new as part of ofhg proc above.
dunno. could be. careful its not tranny grind/wear
roof motor easy fix/relocation. multiple threads here.
u shouldnt be paying more than 3.5k poss cheaper. got mine for 3.5k after seller was asking 4.5k.
link to ad?
If your into doing the work yourself and confident then could be a bargain. I'm not and would pass that one by.
