VANOS solenoids
Scooba_Steve
Elite
 NW London & Somerset
Looks like the other one is giving up the ghost, replaced the top one a couple of years back and got a slight surge followed by EML on the journey home yesterday.
Also had a bit of an erratic idle at times but the VANOS is the only code showing.
My questions is has anyone used aftermarket solenoids? I don't have an issue using genuine but if one a third of the cost does the same job then I'm willing to give it a try.
I've done that before with the previous one that eventually got replaced, didn't last. I will be giving it a clean but am anticipating it coming back so will be getting one in stock to replace.
I am mostly of the buy once, cry once mentality, but if anyone has used an aftermarket solenoid and had no dramas then I'll give it a go, just because I know BMW have a hefty mark-up.
I bought 2 aftermarket solenoids to replace mine after getting error codes, had no issues since... whether they last as long as oem only time will tell!
Thanks Chaps.
When did you put them in Chris? My last was 3 years in Dec from BMW.
Scooba_Steve said:
Thanks Chaps.
Only about 6 months/5k miles ago
markplant said:
mikes thread, it may tell you which he used
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=97381
Mike did the m54 pre facelift engine which is different than the n52!
