maupineda said:
It may change based on your region, but Beisan systems would be my choice for seals. About the pump disc, make sure you have yours re-drilled so you keep yours. also, a couple of words of advise
Make sure you...
1. Test VANOS with ISTA+ or DIS, if all is in spec DON'T mess with it
2. Check your VANOS pressure (https://nam3forum.com/forums/forum/main-forum/e46-2001-2006/529-e46-m3-s54-vanos-pressure-tests)
The VANOS thing is an overblown internet paranoia, only fix it if broken. Have a look at posts #16 and #31 on the link shared above so you can see my actual testing results
Interesting thread. Did you change the VANOS accumulator in the end and did it fix anything if so?
OP, if you’re taking it to a garage for the work most competent ones will be able to get the parts for you so wouldn’t worry about that. If you have to get them yourself either Besian or Hack Engineering or Mr Vanos can supply I believe.
Personal opinion if you can get to Mr Vanos for the work I’d do that, replaces the unit and you get a warranty, job done.
