VANOS Query
PaulJD
Hi All,
With Regards to the whole Vanos issue even if it wasnt starting to make the death rattle is it worth getting and fitting the Beisan seal kit?
I've read that some peopl describe their cars as much improved after the works been carried out, and does 4 hours to do the job sound correct?
Eventually the seals will start to fail so it's just a matter of carrying out this one-off job for peace of mind.
No idea on the time required although searching through the forum should come up with guides and time estimated for the job.
I had my seal done cost £600..
i'l pm you my experience..as you will more then likely end up where i had mine done from.
