Hi,
Am wondering if anyone can offer any opinions on my problem...
For the last 3 months i have had very decreased torque under 3k revs, after 3-3.5k rpm it pulls fine. I have tried to fix this issue myself and have done the following:
reconditioned vanos unit with seals and actuators.
New valve cover gasket and cvv valve.
New intake and exhaust cam sensors.
Still the problem persists, very occasionally the car will run fine low down but there is no pattern to this, 9 times out of 10 is struggles to pull from low revs.
So i have taken it to an independent and the autologic shows no signal from lambda bank 2 sensor 2, and mechanical fault code with the vanos.
The mechanic wants to remove the vanos and check the timing. Does this sound logical - if the vanos timing was out would it be ok to drive sometimes and not others?? Dont really want it stripping down again after i have just done it! Labour costs etc.
It had an oil change in January but by a run of the mill garage, Could they have put wrong oil grade in and would this theoretically cause this issue??
Or could the post cat lambda be the cause of all these issues?
The car is running rich also as carbon deposits on plugs and on the back bumper, presume because the vanos isnt working low down.
What would peoples advice be for me?
Spent so much on the car in the last 3 months Im really gettin stressed now.
Any help appreciated!
Its a 2004 3.0i by the way!
