Valve sensors
RoyE
 Norfolk
I have just fitted new wheels and winter tyres to our zed. I tried to initialise the monitoring sensor by the manual instructions but with no joy. After a visit to the dealer, I discovered the Zeds are now fitted with sensors on the valves as opposed to a monitoring system using ABS.
As I didn't purchase the wheels from the dealer, it is going to cost me £378 to have these valves fitted.
Please be aware!
Glad you posted that Roy. In the market for a winter set up & have been trying to find out about this. Do you have the flat tyre warning lights up ?
The lights come up with the message 'inactive'. The valves look different with what I can describe as a thick base to them. This is with the benefit of hindsight. Apparently, the system has changed on the Z4 in the last few months. I am in discussion with BMW Autosport, who I bought the new wheels from, for a solution.
Titantim did mention on a different post how the new valves were on all BMWs from May 2014 i think ?
Smacks of customer shafting if the valves are so expensive which no doubt you will have to buy from BMW :x especially so as the old system has been working quite well for over 10 years
KERMIT1970 said:
The tpms sensors are available on eBay £52 each I see.
Still a kick in the nuts for something that's been changed for no apparent end user benefit :cry: a solution to a problem that didn't exist :?
It is :x don't think I'll bother with winters now ! Wish me luck :headbang:
Why not go for winter tyres on your current rims ?
I was at a place yesterday with 255 30 19 & 225 35 19 Blizzaks with 5/7mm tread so they are out there :thumbsup:
Wow didnt know that... They are now using tpms sensors.
Strange really.
Sent from my iPhone 5s using Tapatalk
Still a kick in the nuts for something that's been changed for no apparent end user benefit :cry: a solution to a problem that didn't exist :?[/quote]
It is :x don't think I'll bother with winters now ! Wish me luck :headbang:[/quote]
I was at a place yesterday with 255 30 19 & 225 35 19 Blizzaks with 5/7mm tread so they are out there :thumbsup:[/quote]
Whare was that Andy ? What kind of money ? :thumbsup:
Surely this will aslo mean an extra cost when replacing tyres as the valves are normally replaced along with the tyres.
Cant see many people wanting to add an extra £50 on top of a tyre change for a new valve though.
Valves dont last forever. A few months ago I had a valve perish,split and start leaking air on the mini, if I hadnt noticed it it would have eventually burst altogether.
Not necessarilythe same thing but I had TPMS on my 350Z (non UK spec BTW) and they gave me a surprisingly display of the pressure in psi of each wheel.
Yes, I guess they added some cost, no they didn't need changing with every tyre or indeed at any time in 6 years of ownership, they had IIRC an ally stem and were the same system as installed to Renault cars.
In my opinion a very useful item and they were a whole lot more accurate (and use) than the system on our E85/86's which is based around sensing changes to the diameter of the tyre, which to my mind is an inaccurate way of doing the job.
In my opinion the Datsun version was far superior to the BMW version I have today whisch I think is next to useless since it didn't detect low pressures when I swapped over from fully inflated summer wheels to my winter wheels last autumn and drove to the local garage to pump them up as they'd all gone down 3-5psi!
I remember reading somewhere that the EU intended to mandate TPMS at some point so it might be due to this?
In any event I think it's worth the extra cost at purchase if it keeps me safer or gives me some level of comfort that it does!
And in the case of your leaking tyre/valve would have quickly told you which wheel had low pressure so you could deal with it before it damaged the tyre carcass let alone burst!
ETA
From http://en.wikipedia.org/wiki/Tire-pressure_monitoring_system
From November 1, 2014, all new passenger cars sold in the European Union must be equipped with TPMS
The significant advantages of TPMS are summarized as follows:
Fuel savings: According to the GITI, for every 10% of under-inflation on each tire on a vehicle, a 1% reduction in fuel economy will occur. In the United States alone, the Department of Transportation estimates that under inflated tires waste 2 billion US gallons (7,600,000 m3) of fuel each year.
Extended tire life: Under inflated tires are the #1 cause of tire failure and contribute to tire disintegration, heat buildup, ply separation and sidewall/casing breakdowns. Further, a difference of 10 pounds per square inch (69 kPa; 0.69 bar) in pressure on a set of duals literally drags the lower pressured tire 2.5 metres per kilometre (13 feet per mile). Moreover, running a tire even briefly on inadequate pressure breaks down the casing and prevents the ability to retread. It is important to note that not all sudden tire failures are caused by under-inflation. Structural damages caused, for example, by hitting sharp curbs or potholes, can also lead to sudden tire failures, even a certain time after the damaging incident. These cannot be proactively detected by any TPMS.
Decreased downtime and maintenance: Under-inflated tires lead to costly hours of downtime and maintenance.
Improved safety: Under-inflated tires lead to tread separation and tire failure, resulting in 40,000 accidents, 33,000 injuries and over 650 deaths per year. Further, tires properly inflated add greater stability, handling and braking efficiencies and provide greater safety for the driver, the vehicle, the loads and others on the road.
Environmental efficiency: Under-inflated tires, as estimated by the Department of Transportation, release over 26 billion kilograms (57.5 billion pounds) of unnecessary carbon-monoxide pollutants into the atmosphere each year in the United States alone.
The mini has the same system as the Z for monitoring tyre pressures.
Thats how I found the valve had split, the light came on on the dash and I looked initially for a nail or a screw inthe tyre but found the valve to be split instead.
It had only lost a few psi and wasnt flat so the system does work, the only thing it doesnt tell you is which tyre to look at but a check with a pressure gauge is all you need.
Is there a way to check what system I have?
Bought a set of winter wheels on eBay then read this. :cry:
My Z4 manufacture date is feb 2014.
You will have big silver valves if you have the new style TPS
Cheers, had a google and found some pictures of the silver ones. Mine just look like bog standard ones.
A few weeks and ill get them changed over.
:driving:
They are fitted to cars with manufacture date from May14 onwards. Costing me £360 to supply and fit valves at the stealers.
These sensors are now out of stock from BMW. I bought a set from TPMS warehouse at £70 each. They are now fitted and working. £100 cheaper than the stealers.
