I am driving a 2006 z4 e85 2.5si
Imagine divided the brake pedal by 10/10, 1-10 from shallow to deep
Usually the brake start working when apply 1/10 brake,
However, my car's brake start working when applying 5/10 brake, and the situation is getting worse day by day
the garage worker replace my car with a new master cylinder with the procedure of replacing brake oil
the brake is fine at the beginning, and soon getting worse as before
I check with my other friends that they also own a 2003 z4,
they have a different design of master cylinder (two more socket at the bottom), is that the possible problem?
the garage worker said the problem is from the brake pipe, is that true?
please see attachment with more details
Thank you very much
Thank you very much
