There are many warnings on this forum to avoid the facelift 2.5i as being underpowered, so not being a speed freak, I bought one.
First impressions are that it is the smoothest and quietest Z4 that I have owned and, if I hadn’t been spoilt by previous M54 3.0i and N52 3.0Si variants, it is plenty powerful enough for this type of car.
I suspect most of the “missing power” is at the top end, which is not where my automatic spend most of its time. The 2.5i delivers 177bhp at 5,800rpm compared to the 2.5Si’s 218bhp at 6,500rpm.
So what’s the difference? It seems to be all about the intake manifold and ECU tuning. The 2.5i has only one DISA valve (not the same as the US spec 3.0i, which doesn’t have any), whereas the 2.5Si has two. The intake manifolds themselves have different part numbers (as do the 3.0i and 3.0Si), but all the associated hardware, including the gaskets, is common across all four engine designations.
A common modification in the US is to replace the 3.0i manifold with the 3.0Si manifold for a bolt-on power increase, with further increases available by tuning the ECU.
It should be possible then, to release power in the 2.5i by simply swapping out the manifold for one with 2 x DISAs from the 2.5Si or 3.0Si. Online sources suggest 15-20bhp, with an ECU tune required to release full 2.5Si power.
Unsurprisingly, I’m on the look out for a manifold with part number 755 9523 or 755 9525 (common across many N52 applications) if anybody has one and is interested in whether this power gain is a reality.
What about the N52B25 fitted to the E89 23i? This produces 204bhp at 6,400bhp. It has exactly the same manifold and DISA configuration as the 2.5Si, but is down on power by about 15bhp. I can only assume this is to do with the ECU tune, unless anyone knows any different. Anyone out there flashed theirs with a 2.5Si tune?
Constructive thoughts and advice welcomed.
