Under car shroud broken and now removed-replace?
JeffInMonterey
New member
Took my car ('06--34,300 miles) in to the garage due to a faulty alternator the other day, and had them check out the plastic shroud under the engine. It was badly damaged, and a mounting bolt on the frame was broken off. They removed the shroud and I am wondering if I should have it replaced? I will need to go to a body shop to have that bolt replaced (welded to the frame), and get a new shroud. Is it necessary or advisable to have it replaced. I can't seem to find the part number at RealOEM, or a diagram to see how it attaches.
Jeff
Monterey, CA
