Morning all,
With the enforced lay up of wifey's 2.5i I have dug out the solar charger from the garage to keep her battery topped up a little. It hangs under the front of the car port, out of the rain, and facing the sun for most of the day. Working a treat.
It comes with crocodile clips which fit fine on the under-bonnet points, but obviously I cannot then get the +ve terminal cover back on, and it's a faff to disconnect when she does want to use it.
The crocodile clips are on a shortish length of cable with a plug so they can be disconnected from the longer cable to the solar charger.
I would like to permanently install the shorter length of cable in the car, replacing the crocodile clips with ring connectors, thus satisfying my tidy mind by being able to put the +ve cap back on.
Before I dive in and knacker something, can someone please tell me if the two hexagonal connection points under the bonnet are able to unscrew, to fit the ring connectors under?
Thank you.
Thank you.
