Common Faults
Here is an excellent link to all the Service Information Bulletins (SIBs) for the E85/E86/M.
[*] All Z4s have a high failure rate on rear springs. Good news is, it's a relatively cheap replacement.
[*] You can reset your one touch window open / close (if active)
like this
[*] On Roadsters, the
drains will need cleaning which if left will corrode your roof motor, with substantial repair bills. This apparently forms part of Inspection I & Inspection II, but check with your dealer this has been checked.
[*] If your roof motor has failed, expect large repair bills from a dealer (£1000+). Shipkiller has kindly
documented his replacement which will make this lots cheaper, as well as
how to remove the roof.
[*] Facelift Zeds have a sealed roof motor to limit this problem.
[*] If you have an
ODB2 lead you can list any stored faults, the definitive list is of these codes is
here.
[*] All Z4s have a Clutch Delay Valve, which can give the effect of "kangarooing" in 1st/2nd gear.
This can be removed by you or an specialist.
[*] If you have an illuminated Airbag light, it's likely your door airbags were disconected without the battery being removed, but there have also been occasions of failing seat occupancy sensors which cause this.
[*] Failing electric windows are often due to
Window Regulators - telltale sign is a rattly door.
[*] Sticky / Non-working wipers? Check out
this excellent thread.
//M Specific
[*] The "features" of the CDV are very noticeable on the /M and will often result in Kangarooing in 1st/2nd changes.
[*] Z4Ms all have a noticeable VANOS noise at about 3-4k RPM. This is completely normal.
[*] t's fairly common to detect issues with the allignment of an /M, resulting in often pulling to the left.
[*] Most Z4Ms will also need a new O2 sensor once in a while, it's fairly common to have had both replaced by about 30k.
[*] As /Ms have a Limited Slip Differential, you can only disengage the DSC fully by holding the switch.
[*] Some early Z4Ms have noted grinding between 1st/2nd gear which have resulted in Warranty gearbox replacements.
http://www.z4-forum.com/forum/viewtopic.php?f=9&t=17429
