mr wilks said:@nictrix,
265 30 19 on 10j is as you point out "undersized" I would be on 265-35-19 or 275-30-19 either of which would increase contact patch over 265-30-19 & give rim protection + improve ride comfort
I think your post here shows you understand as much as you need to. Wider profile gives more contact area, a greater wheel diameter does the same but only very very marginally.Nictrix said:Oooohh you made yourself look all clever by trying to spell it out but really it just looks the same with no explanation. :thumbsdown:mr wilks said:Nictrix said:Can you explain this bit as I dont quite understand it. It doesnt make sense in my head.
I'l tryhere we go nice and slow
a 2 4 5 - 4 0 - 1 8 tyre fitted to a 8.5j rim will have a greater contact area on the tarmac than a 2 5 5 - 3 5 - 1 8 tyre .
It was a simple question that I thought you might have been able to explain.
Surely a 255 tyre has 10mm more tread across the width of the tyre in contact with the road than a 245, so how does increasing the sidewall by 5% increase the contact area of the tyre?
mcbutler said:I think your post here shows you understand as much as you need to. Wider profile gives more contact area, a greater wheel diameter does the same but only very very marginally.Nictrix said:Oooohh you made yourself look all clever by trying to spell it out but really it just looks the same with no explanation. :thumbsdown:mr wilks said:I'l tryhere we go nice and slow
The fact remains that BMW know best when it comes to tyres. More rubber will lower your aqua planing speed and reduce grip in the wet generally.
May be better in the dry but I am not a tyre/suspension etc engineer or developer.
