Tyre Sizes on OEM CSL wheels
Attilio
Dublin
Hello all,
this is a topic that has most likely discussed to death over the past years but - hope you don't mind - I would like to add another layer to it:
I am about to get tyres for my new OEM CSL wheels (as soon as I will have some clarity about the lifting of restrictions here in Ireland).
My understanding is that the E46 M3 CSL sizes - R19 8.5" front and 9.5" rear width rims - are (were) 235/35 R19 and 265/30 R19 respectively.
Now, the OEM sizes for the Z4M are 225/45 R18 (front) and 255/40 R18 (rear); I am thinking that it may make sense to actually fit 225/35/R19 (front) and 255/35 R19 (rear) to maintain a near-identical rolling circumference and at the same time not reducing the sidewall too much. I am aware that the tyres may be a bit stretched once the same width is fitted to a 1/2 inch wider rim
Any opinion / experience in this regard? Have any of you maintained the same tyre width while going up in diameter?
Thanks in advance for your input
Attilio
I use 265/35 rear which is close to OEM diameter and looks good imho.
(Also better comfort and better gearing on motorways)
The OE CSL sizes would be a better option, they are wider than your suggestion and so will offer more grip.
I think I ran 235/35r19 and 265/30r19 when I had them on mine - but I found them too crashy with the OE suspension, so replaced them with 224M wheels after a couple of months (did a part-ex with someone on the forum).
If I were to go to 19" wheels again, I'd definitely put bigger rubber on them - the 265/35 r19 sounds fine, but I'd even go as far as trying to get away with a 275/30r19 if I knew there'd be no rubbing.
You can but it won't leave much protection for the wheel. Standard sizes give your a bit more rubber on the road and a little more protection.
Ive run OE sizes 235s/265s for years on mine and its been spot on 👍🏻
Others do run different sizes and you can run a 255. Depends on the tyres sometimes you can get better deals etc
Interesting on the crashing I don't find any difference what so ever, my last car had H&Rs and im on standard sus atm and if there is a difference it is very negligible.
Thanks for your responses guys, really appreciated it!
I think I will go for 235/35 R 19 at the front and 265/35 R19 at the rear!
Thanks again :thumbsup:
Attilio
MichaelK said:
Does anyone get arch liner rub on full lock with the 235/35/19 fronts? I seem to on my passenger side
Is your car lowered and are you running spacers?
I’ve just fitted some CSL wheels fronts 235/35/19 and I’m getting some rubbing on the outer front edge when I go round corners on the drivers side? Car was lowered by previous owner with H&Rs!
I’ve jacked the car up and it doesn’t rub on both locks but it’s very close! Would 225/35 on the front solve the problem?
